doorskin
Posted: Mon Aug 24, 2009 6:09 pm
by ianminki
hi rob
still no word yet about the doorskin could do with it now .. what im looking for now is the best way to fit the catches for locking the front end down . i got a pair of aerocatchs but not sure where and to fit them .. think i mite have got rong sort.. was thinking of them rally type pins for top of bonnet close w/screan then the aerocatchs about midd way along the bottom but not sure about the pins for them cuold u help or know sombody thats used them
thanks
Re: doorskin
Posted: Mon Aug 24, 2009 7:12 pm
by Cerberus
ianminki wrote:hi rob
thanks
Alec Martin on here has used Aerocatches.
Re: doorskin
Posted: Mon Aug 24, 2009 7:40 pm
by alecmartin19
hi!
yes as mentioned, i used aerocatches. if you look at my pictures on the website you can see them fitted to the car and also some of the process of fitting them. i did however have to modify the pins and the catches slightly as the original aerocatch the pin only comes in from underneath at 90 degrees to the catch and i needed it to come in from the side. i just cut away part of the back of the catch and filed a little off of the pin to make it thin enough to mate with the catch. if you need some pictures, i'll try and get some more!
Re: doorskin
Posted: Mon Aug 24, 2009 10:00 pm
thanks
I might be able to copy the door skin on mine as not yet painted if you want me to try let me know and will give it a go and what side.
