wiper motor? hummm what should it be fused at? anyone know
Posted: Sat Sep 11, 2010 9:31 pm
by flipper123
just got a few niggly bit of the wiring to finish got all my part and switches but im not sure if the wiper motor need a separate supply of its own or can i spur it off another circuit, what should i fuse it at? tried trawling the internet but there seems to be not much info. or mayb e im being a bit over careful. cheers any help would be great.
from craig
Re: wiper motor? hummm what should it be fused at? anyone know
Posted: Sat Sep 11, 2010 10:12 pm
i think mine is 20 amp
Posted: Mon Sep 13, 2010 8:44 pm
by flipper123
thanks thats a start. i might just try a low fuse and keep up rating until it doesnt blow at least i know then its close to the rating and probably lower than reccomended one.
Posted: Tue Sep 14, 2010 1:02 am
Land Rovers with the same motor use 15amp hope this helps. As a back up if all working ok remove the fuse and fit amp meter in place of the fuse a switch the wipers on on the dry wind screen and get a reading and make sure the fuse is a little greater than the reading.
