Received an Email from Martin -- Via Styluslist -- saying his Damper bolts had rusted in and he would have to cut them out!!
Such a catastrophe should never happen, --- IF you take care and a little time to smear an Anti-Seize compound on the bolts first.
My advice to all Stylus builders, in fact to anybody who bolts anything together that might be out in the Weather and might have to be taken apart sometime in the future, is to ALWAYS use Anti-Seize on at least the threads.
In Good old Oz, we used a product called "Never-Seize" which is lately rather difficult to find, (it was probably too good, so was taken off the market.) or a close second is "COPR-KOTE" ! Again, in Oz, it is a product of the Ampol Petroleum company. It may be available in GB or there is sure to be a similar product under another brand name. It sure saves a lot of anguish later !!!
Rusty Bolts
Re: Rusty Bolts
To be honest mate , I'm astounded at the total lack of maintenance that some builder/owners apply to their pride and joyrossco61 wrote:Received an Email from Martin -- Via Styluslist -- saying his Damper bolts had rusted in and he would have to cut them out!!
I remove the shocks occasionally for a clean up when it's difficult to get at every part --- give the springs a clean --- WD the lot and bolt up using copper grease. WD the chassis too after cleaning off dirt etc.
- alecmartin19
Re: Rusty Bolts
if people carried out maintenance like this on every car it would make mechanics jobs a lot easier and save us all money i'm sure! i use WD 40 on my car after taking it out and its still in the condition it was when i built it!
Never sieze is still available in the UK. we use it here on parts of our aircraft engines that get hot! very good stuff!
Re: Rusty Bolts
Precisely Alec
My chassis is virtually as built and all bolts are original apart from the threads cut off that were over long and the addition of ' K ' nuts , curticy of Mr Bailey
(F1 floor sweepings
