Shocks and Springs
Shocks and Springs
What shocks and springs do you guys reccomend? We are going to be using the car mainly for road use, with some track use too. We both weigh around 11st.
The chassis has the new rear bent arms on it.
I know the main options are ProTech or GAZ. Any others?
Hopefully somthing will come up at Exeter!
Re: Shocks and Springs
If you weigh 11 st and want to track it too , I'd use 1.9 inch shocks / springs (alloy d.adjustable if you can afford them ) 11 inch open at the front with 7 inch 225 lbs springs plus antirollbar(without bar --- use 250 plus) Use 1/4 to 1/3 rd of your shock clicks up front.Pete&Matt wrote:What shocks and springs do you guys reccomend? We are going to be using the car mainly for road use, with some track use too. We both weigh around 11st.
At the rear use 15 inch 1.9 inch shocks with 1.9 / 10 inch 200 lbs springs . Use 1/2 to 2/3 rds of your shock clicks at the rear. Set the ride height so you can live with it on the road probably around 120 to 130mm under front lower chassis rail . Then set rear ride height (just under seat pan where steel joins the alloy footwell) at 20 mm higher than the front.
This is a base setting to start you off (for road AND track
The 20 mm wedge and other settings should give you an oversteering car under provocation . As you go quicker , you'll maybe lessen this wedge by 5 mm or so untill it understeers more than your driving style finds acceptable.
If you end up buying double adjustables , just PM me and I'll explain my own theory on settings o.k.
Thanks for the info guys.
Rob - Do you reccomend running an anti-roll bar on the front for the road? I presume only Tim can supply this?
Is there any make you reccomend? From speaking to Tim on this in the pass, he has said use GAZ shocks as he didnt like the ProTech ones. However, my experience of GAZ shocks hasnt been the best, so im not over keen on using them, unless i can be pursuaded.
You were reffering to "the wedge" what is the wedge??
There will probally be 2 people in the car most of the time, so does the springs you reccomend reflect this, or for a single person only?
Pete&Matt wrote:Thanks for the info guys.
Tim and I designed the rollbar BUT Tim actually made them himself . If he can't be contacted it's quite a simple matter to make them with mine as a pattern. However , I would need to know that he didn't mind me doing it . I'll try contacting him to see how he feels about it ok. He's got some in stock from my memory though.
Antirollbar fitted will help the compromise of road/track so you needn't run 250 or 300 lbs springs up front which you may not like for road use.
Shocks ------ well I prefer AVO or Tracspax alloy double adjusters. Tracspax being 1st choice. If AVO 's , you'll be happy though. Main thing is to jack the car up after an outing and clean the suspension / shocks -- spray with WD --- then next time cleaning is easy. Half the trouble with people's complaints about shock endurance , is them treating the Stylus like a tin top --- never looking underneath/cleaning![]()
Using mainly for road ----------- the spring rates will be fine for two guys BUT if you get serious having tried it on track , we'll need to chat again![]()
WEDGE is simply the difference in front/rear rideheights which should be rather like a piece of cheese --------- wedge shapedlow front -- high rear = oversteer
Remember I said in the previous post ---- 20 mm higher at the rear seatpan area
Shock purchase
DEMON TWEEKS will give you 10 % if you join their POLE POSITION CLUB scheme otherwise contact AVO direct or one of SPAX dealers on the web. Mike Topp motorsport
Go for the 1.9's though --- they're lighter plus a little cheaper
AVO will sell you springs too , otherwise go for FAULKNER race springs
Rob - I take it the following link to the AVO ones at Demon Tweeks are suitable:
http://motorsport.demon-tweeks.co.uk/pr ... APA090/070
Do you reccomend the Spherical or poly bush mounts? Probally go for steel bodies as its a lot cheaper!
Would you be able to try and contact Tim if you have been speaking recently?
Shock & springs
Hi Pete&Matt, Rob et al,
Saw comment about being OK to copy an item if it is not copyrighted or patented. This is just to say that copyright exists without having to be registered or claimed. Someone just has to be able to show they designed and made the item first . This usually means having a dated drawing and records of an item sold although getting registration creates a stronger position.
John McL
John McL
The steel AVO's are fine with poly bush --- I have poly bush rears / spherical bearing fronts. When you scroll through their order sheet you'll find that they list shocks as 1.65 not the 1.9 springs that they will take , I seem to remember . Just mentioned it in case confusion arosePete&Matt wrote:Rob - I take it the following link to the AVO ones at Demon Tweeks are suitable:
I've left a message for Tim regarding antirollbar's ----- I'll get back to you
