I'm thinking of changing to a different material, carbon fibre, steel or stainless, any other suggestions appreciated. On a similar note the underside of my alloy dash seems to get rather warm as well...
Thats the heat insulator sheet that I've already used, it's worked elsewhere, it's just the top that of the footwell that really struggles.B@man wrote:Hi,
The transmission Tunnel in my car gets really hot, this is a double skin of ally so you may be on to something.
(OK when it's cold but cooks you elbow in the summer)
Have you tried that Foil / Glassfibre / Foil sandwitch stuff as it really reduced the temperature of my bodyshell where it is close to the exhaust !
Nissanman wrote:And maybe try exhaust wrapping the manifold to the point wehere it meets the silencer - it will keep the heat in till it gets to the sill.
