ROLLBAR Upgrade: Fisher Fury will fit :)
se7ensport
Post by se7ensport »
I'd been struggling to get a rollbar for over a year from SSC and had given up trying to get Caged to answer the phone or return my calls..... anyway took a gamble that a fury one would fit after looking at one in the metal.
Well I got one made by them, it did take 2 months, but it is bespoke in that its 3" taller than standard, and it pretty much bolted straight in, to get it to fit I am having to make some new mounting plates out of angle iron that bolt between the original two mounting points (i've made them out of cardboard as templates to test- downside is that no steel stockist are open in the area until Jan 2nd :( )
Photos of rollbar and new mounting bracket to follow once I've made them.
norma
Re: ROLLBAR Upgrade: Fisher Fury will fit :)
Post by norma »
se7ensport wrote:I'd been struggling to get a rollbar for over a year from SSC and had given up trying to get Caged to answer the phone or return my calls..... anyway took a gamble that a fury one would fit after looking at one in the metal.
Rob (stylussprinter) is selling these kits as we speak.......
Cerberus
Post by Cerberus »
Rollbar not anti roll bar :lol:
ahh your the man who they were making that for then! thats good to know though as we will be in a similar situation at some point soon! Maybe Rob will add the rollbar's to his list of parts to make?! :)
Roll bar
All depends on interest volume wise . :roll:
se7ensport
indeed, ROLLBAR not antirolbar.
It was ONLY £210 and that included postage and a stupid amount of bubble wrap and cardboard (it honestly took me 25 mins to get is out of the wrapping!!!!)
Cerberus
Post by Cerberus »
If you need my welder or plasma cutter for your brackets you are more than welcome.
:D
se7ensport
cheers buddy, need the metal first :(
se7ensport
it's now fitted
:D
Very simple install; angle iron bolted on to original mounts, then drilled to accept new rollbar. took a total of 2 hours to fit once I had the metal.
