Side Window Seal Cutout?
Just after a bit of advise! I have attached a picture and have shown in red an area which we think should be cut out to relieve the door seal, as it is an un-even step on the other side of the door (see second photo) Is this the right thing to do, or does it not cause any problems when the side screens are put on?
Re: Side Window Seal Cutout?
Can't remember so will have a look at mine and get back to you
Yes, I think you should. The vertical lip along the top of the door is then in line with the lip on the rear of the screen frame when the door skin is aligned with the wing.
Steve.
Steve.
I thought you had to crimp the seal at the pinch points. I cant remember how its done though - perhaps with the other halfs hair straightners (well she told me they are good).
Re- being in linewhiterabbit wrote:Yes, I think you should. The vertical lip along the top of the door is then in line with the lip on the rear of the screen frame when the door skin is aligned with the wing.
Steve.
- spidermike
hi,,i did the same as rob said,just cut the hole thing off then fitted a alloy angle ,did glue and screw them on
put some pics on cant see alot anyway
D YELLO D BETTA
I like the natty top of screen curvature but not sure how that will be easy to fit a hood to , should you want one
Thanks for the advice everbody. Looks like cutting the vertical lip off is the best way to go. Found the previous post on the side screen Rob. What's this boat glue you spoke of?
The return on the top of Spidermikes screen looks good, but doesn't look as though you use a hood.
Peter (Matts on holiday lucky sod)
- spidermike
hi Peter..just been mesin with the side screens was thinkin of fitting some kind of rag top like the half top r something ,
was guna put holes in the tops of the screens and put togles in the hood
somethin like that any way
so as 2 doo away with the need 4 hood metal
r maybe a hard top ...........
p/shop
mike
o and sliped the exhaust out the side as pr Robs posts, info ,etc (was meltin d plastic)
D YELLO D BETTA
Hello Peter , not like you to postPete&Matt wrote:Thanks for the advice everbody. Looks like cutting the vertical lip off is the best way to go. Found the previous post on the side screen Rob. What's this boat glue you spoke of?
We have a few boat yards/chandlers around as we are on the coast so will try and see what they have.
It's Matt the younger who normally posts, I don't normally get a look in!!
Maybe you'll get the build finished while he's on hol's then and surprise himPete&Matt wrote:We have a few boat yards/chandlers around as we are on the coast so will try and see what they have.
