Castor
Cerberus
Castor
Post by Cerberus »
I need a set of bottom wishbones as i can't get any castor adjustment on mine, the way they are made means i can't do anything, i'm running 3* positive, i need more. Any ideas?
Re: Castor
If you're not prepared to go rose joints then another cheap way to get more would be to cut down the chassis end mounts/tube (once poly's are removed) -- tidy up with the welder / grind off etc . That will give you scope to shift back and forth after you've cut the poly and inner sleeve to suit. Then fit spacers or washers to hold in place.
Cerberus
Re: Castor
Post by Cerberus »
I would like to go Rose joints but the shape of my rear tube won't let me, it's a flat oval if that make sense.
Antnicuk
Re: Castor
Post by Antnicuk »
its only metal, anything can be done :mrgreen:
