Front to Rear Wedge
Front to Rear Wedge
How sensitive is the chassis to adjustment, will 1mm make any difference or is there a minimum of say 5mm before you notice anything? the reason i ask is the nearside rear is a pain in the arse to adjust with a C spanner i'm currently running 18mm and it oversteers when having fun.
Re: Front to Rear Wedge
It very much depends on how fast and or agressive you're going for oversteer to occur --- ie. are you meaning to hang the tail out or is it catching you out
Regarding noticing 1mm wedge adjustment , I would say that you would only notice by monitoring lap times . 5mm yes , you'll notice. Higher = more oversteer . Lower more rear grip but more understeer --- pays you money and takes your choice This assumes that all other parameters of adjustment are ok / tyre pressures , shock settings etc etc.
stylussprinter wrote:It very much depends on how fast and or agressive you're going for oversteer to occur --- ie. are you meaning to hang the tail out or is it catching you out
It's catching me out, its not bad just seems to slip slightly then grip again which is unerving (hard to explain more like a little protest from the tyres) as for springs/shocks =250lbs F 200lbs R played with settings and i am happy with them, tyre pressures are 16lbs on Toyo T1S, i think i will drop the rear slightly and see what happens, i did have 300lbs F 250lbs R but it was to hard and understeered badly, whereas now the front turns in and grips beautifly having said that i do nee to make some new lower wishbones to give a bit more caster as i have only got +3* which makes it a bit unstable at speed.
How old are the tyres -- are they getting hard after 2 to 3 yearsCerberus wrote:stylussprinter wrote:It very much depends on how fast and or agressive you're going for oversteer to occur --- ie. are you meaning to hang the tail out or is it catching you out
16 psi for Toyos is low for best performance , Yokos are ok at 16 but 17 at lowest for toyos .
i've worked the pressures down from 20lbs in 2lb increments 16lb feels better especially on the fronts, so i will take the rears back up and see, i really need to get it on a track two days would be nice, on the plus side my latest engine seems strong
