Can't win um all aye
I could really do with one or two pit crew / I'm on my tod this time --------- any offers
Checked whilst off the ground and I was wrong --- bearings are fine so must have been something sounded/tapped when I rocked the wheelstylussprinter wrote:I just may have found my vibration on braking -------- driver's side wheel bearing is a tiny bit loose when I flipped the front and gave the front wheels a shake
Rod-ends ? - centre pivot backlash & lock nuts OKstylussprinter wrote:Checked whilst off the ground and I was wrong --- bearings are fine so must have been something sounded/tapped when I rocked the wheelstylussprinter wrote:I just may have found my vibration on braking -------- driver's side wheel bearing is a tiny bit loose when I flipped the front and gave the front wheels a shakeNext step will be to get both front wheels balanced --- can't see any fresh marks of weights come off
Just got the results via Gary Goodwin which shows me 2nd in class but 11th overall , so a tiny plus to feel good over![]()
Interesting that my friend's J15 with 2lt Duratec with TB's 220bhp , weighing 550kgs best timed was 100.9 secs but he's getting quicker each event he's entered (3 Goodwood's this year since new build)
Rodends top outer were replaced when I refitted engine and box --- only the front left was worn OR rather the kevlar was coming out but I did both anyway. The bottom x 3 each side , appear to have no play but I'll check again , seeing as I can't find the cause yet.MattD wrote:Rod-ends ? - centre pivot backlash & lock nuts OKstylussprinter wrote:Checked whilst off the ground and I was wrong --- bearings are fine so must have been something sounded/tapped when I rocked the wheelstylussprinter wrote:I just may have found my vibration on braking -------- driver's side wheel bearing is a tiny bit loose when I flipped the front and gave the front wheels a shakeNext step will be to get both front wheels balanced --- can't see any fresh marks of weights come off
