What have you all done with regards to blocking off the speedo cable drive on the Type 9 box? There appears to be no aftermarket solution for it that I can find.
Any suggestions would be appreciated.
Type 9 speedo drive - blocking off
- pigeondave
- Are you a Stylus owner?: no
Re: Type 9 speedo drive - blocking off
Quick call to Chris at BGH?
http://www.bghgeartech.co.uk/
BGH Geartech Ltd
Red Roofs
New Road
Cranbrook
Kent
TN17 3LE
Tel: 01580 714114
Fax: 01580 714114
BGH Geartech Ltd
Red Roofs
New Road
Cranbrook
Kent
TN17 3LE
Tel: 01580 714114
Fax: 01580 714114
I still use that drive but if it's a problem you could manufacture a little alluminium disc to slightly more than the drive diameter . Then tap it around the circumference carefully ----- make sure it's non greasy and dry --- Sikaflex the disc over the drive but no Sikaflex must get into the inner drive area. Simples
I will give Chris at BGH geartech a call too. He has been very helpful in the past.
If not I will do as you have suggested Rob.
Apparently you can use a 2p as it's the right size....see below
http://www.rhocar.org/index.php?showtop ... ntry330358
