Wirning Loom
Stylus related discussions
Wirning Loom
Does anyone have a wiring diagram for the Premier Wiring Lucas based loom that Tim used?
Currently having issues with the indicators! The hazards work fine when the mini steering column stalks are disconnected. As soon as i plug them in and try the indicators it blows the 15 amp fuse instantly! Therefore there appears to be a mega short somewhere. All other controls from the stalk work correctly.
I have matched the wires on the loom to those on the stalk in terms of the lucas based colour coding.
The loom doesnt come with a wiring diagram or any instructions on connecting the stalks up.
Have sent an e-mail to Alan at premier wiring, but he has ceased trading now so takes a while usually to respond.
Thanks in advance!
Car nearing completion now! yay!
Re: Wirning Loom
I have Alan's original instruction sheets somewhere but haven't a clue where , so mot much help but will certainly look.
Re: Wirning Loom
I have the orignal instruction sheet, but has nothing about the indicators etc on it
Re: Wirning Loom
Ive got one Matt, will dig it out. Not sure what's on it mind !!
Re: Wirning Loom
Ok thanks!
Re: Wirning Loom
All sorted now! The issue was the indicator light on the dash was shorting out. This is the 4th out of 6th that has done it now. Usually they get hot, but this just kept blowing the fuse, so a process of elimination!
Thanks for your help, another item ticked off the list now!
