This was due to incorrect spring rate which allowed total compression of the springs --- leading to the '' spring/shock '' becoming a solid mass SO the arms had no option BUT to bend . Compounding this , the shock length and rear arm is also incorrect for the Stylus's average weight.
This is really simply historic , as Jeremy Phillip's very first design for the Stylus copied the spring rate on his Striker plus shocks were SPAX not AVO or any other make. The SPAX had a different stroke travel than AVO for similar body length too .
SO WHAT WERE the original springs/shocks
This tended to set the car very high compared with the demo car(Spax onto JP's rockers/arms) SO when I tried to lower my car to match Pete's demo = bent arms
My first solution , in ignorance , (I already had 12'' shocks on 8'' springs) was to put 200lbs springs up front and 180lbs on the rear. This helped but was not the complete answer . A further temporary move to save cash was = I drew up a cardboard pattern for a bracket to fit between the front lower shock pick ups. This gave me' lower shock mountings' closer together so I could then lower the car and still have more shock travel . This worked well but was frowned on by a few people
The point of this post is to say that Tim's answer to the problem was to redesign the suspension to suit the requirements of the Stylus and acheive a lower ride height but still have good all round shock travel
I.E. greater angle or any angle you choose for the front rocking arms = good travel/lower car
Concave rear arms plus longer shocks = good travel/lower car
The result of this is a better stance and roadholding/handling/comfort of your car . They are in stock now because I've just bought some for the 'green' Stylus I'm renovating so Tim's just made up a few sets.
Pic' attached of the rear arms/suspension on my 'green' Stylus
