Rear dampers
Rear dampers
Is there anyone who can tell me if the rear dampers on the escort axle are the same lenght as the fronts (mine are). Looking at the pictures of the finished cars there is about 2 to 3 inch above the tyres to the arch. Mine the arch is level with the top of the tyre, the damper is almost fully extended. I have the Protech dampers and the bent lower arm.
Re: Rear dampers
If you have curved lower links then you need 14 inch shocks/9 inch springs . Phone Tim ssc to check. It's desiged to give you more travel without bottoming out therefore better grip/handling.hearbear wrote:Is there anyone who can tell me if the rear dampers on the escort axle are the same lenght as the fronts (mine are). Looking at the pictures of the finished cars there is about 2 to 3 inch above the tyres to the arch. Mine the arch is level with the top of the tyre, the damper is almost fully extended. I have the Protech dampers and the bent lower arm.
Rob(I run 14 inch and 8 inch springs but had to cut the arches to make use of the adjustment)
