It runs under the car and has had so many knocks, its now about 1.5" dia at the point at the back of the seat where it goes up at 30 degrees towards the silencer.
Anyway - its alwayd been noisy and always been down on power - now running 200bhp spec Zetec and mapped at 185
Went to Oulton Park today for a track day and failed the 105db noise test at 5000rpm (3/4 max revs) so the nice man said "drop it to 4500" which i did and it came out at 105db!
Anyway - I then failed drive by noise test and was black flagged.
Legged it to Demon Thieves and got a db reducer pipe - fitted and tested for afternoon session - still 105db (sounded exactly the same!)
Anyway, they let me out and "looked (or rather listened) the other way" until 4.30pm when they'd had enough and dragged me in again (shame really - I was really on it).
So I've decided I must sort it this winter - I don't really want to put the pipe through the sill as I prefer the look of a standard sill and exhaust out the back.
So no my feeling is, get a 3" exhaust pipe, flatten it to 40mm (so its oval) this will give me the same open area as a 2.5" system (which is what I need for 200bhp).
This would overcome my exhaust scraping moments - and hopefully a new manifold + system might/should bring down my volume too!
So my idea is, new 4 branch manifold, mated to 3" pipe that is then 'ovalised' for its journey under the car, where it goes up towards the fixed axle, go back to 2.5" for silencer and tail pipe.
Of course by putting the exhaust underneath again - I am not able to lower the car any (which would be nice really).
Just wondered what you guys have done - suppose I'm hoping that one of you has had a Eureka! moment that they would share with me
cheers fellas
