I spent 2 hours this evening just messing with the position of the engine and box, I think i am happy with it.
The shifter is in the right place, the sump sticks below the chassis rails by 1.5 inches at the lowest point. The gearbox has clearance in the tunnel, the front of the engine is about 6 inches behind the centre of the front wheels , the starter motor fits without cutting the passenger footwell and the bonnet fits without cutting more holes. Basically, making brackets to fit the engine mounts to the chassis and a gearbox mount and its in place with no more work fabrication.
I will sleep on it and see what i think next time i look at it, if i think i want the engine further back, i will look at cutting a little of the bottom corner out of the footwell. That way the whole lot will go back further, i could probably go back 3 - 4 inches and still use the shifter ok.
There are several other options which i will consider, 1st: I'm using a RX7 Turbo II box but the shifter on an RX8 box is 3- 4 inches further forward so the gearbox could go back and the shifter would still be in the right place, only thing is the RX8 box looks a little fatter than the turbo II and i only have half inch either side of the box in the tunnel as it is.
For the starter motor issue, the starter is the only thing stopping the engine going further back, automatic cars have the starter motor mounted parallel to the engine pointing to the back of the car whereas my manual starter bolts in the back of the bellhousing, parallel to the g/box pointing forwards. I could machine the back of the engine and fit an auto starter. Probably easier to just cut some of the footwell out though.
SO. My questions this evening are...... How much benefit do you get from mounting the engine further back? Is 3 inches going to make a difference?
and
How much do your sumps stick out below the bottom of the car?
Not much room to fit an Engine mount in there, any ideas on what i could use, the rotary ones are huge.
Shifter is about perfect.... i think
Starter and tunnel clearance. (thats a spacer behind the starter)
Sump clearance..........
No Bulge required.................... its close though, the bonnet is sitting on the inlet manifold!
