Silencer
Posted: Tue Mar 31, 2009 9:13 am
by Camoradi
Hi all,
When I bought my Stylus it had a rear exit silencer which soon rusted through and fell off
) I "converted" it to side exit as a temporary fix, but it's way too loud so I've decided to fit a decent (sub 100 db) system with side exit. I'd appreciate anyone's experiences or recommendations in this regard, please. I'm thinking a 6 inch diameter by maybe 24 inches long stainless silencer should do the job, based on what I had on a previous kit car. The engine is a Zetec on throttle bodies running at circa 160bhp. Based on your experiences do people think this will keep it under 100db? Also I've seen Wunoff mentioned as a potential source. Does anyone have any other recommendations?
thanks
Kev
Re: Silencer
Posted: Tue Mar 31, 2009 9:48 am
Kev' , if that's the green Raceline 1.8lt that I sold to M.Berry then it will have an open side vent in gold that I made for it. A 6inch silencer at 24 inches will do the job to sub 100db's BUT only if it's a re-packable and packed with Basalt .(stainless wire wool wrap one layer the perforated pipe and wire tie first) Lightly prod the basalt into the silencer using a half inch bit of dowling -- not hard nor loose -- using finger pressure rather than a fist
VERY important though ---- don't try to keep the silencer within that golden grid and F/glass sill with a 6 inch ' can ' --------- you will eventually cause a fire. Cut 2 inches below the door then right underneath to the alloy extension on the chassis. Open a nice rounded oval the full length of the silencer , clearing the F/glass by a minimum of 20mm. Then you need air in as well so cut very large 3 to 4 inch holes under the sill where the manifold passes --- 4 or 5 if room . Mount the silencer only at the rear end via a 3mm thick circular strap that will bolt into the same holes as the end cap. Then that strap needs an extension 90 degrees to it . That then sits on top of a rubber bobbin which should be bolted onto a piece of alloy angle , itself bolted through the chassis , coming though near the passenger seat.
Too many kit cars have gone up in smoke through big silencers within the sill if not totally exposed.
Here's how
(You can see here that it protrudes out from the body about 20 mm's ------ also the alloy angle mount & bobbin on top)
Re: Silencer
Posted: Tue Mar 31, 2009 10:55 am
by Camoradi
Hello Rob. I was hoping you might reply, as you know the car. Thanks
(I'll post up some pics of the work I've done sometime soon)
Yes I am going to cut away the body work to give clearance, and fit the silencer as you suggest. So far I have removed the silencer and all the heatproof matting from the chassis and bodywork (revealing a bit of rust caused by moisture retention). Once I've cut back bodywork I'll replace the heatproof matting and add the extra ventilation holes (thanks for that tip) ...I'll go the repackable route as well.
Kev
Re: Silencer
Posted: Tue Mar 31, 2009 10:00 pm
I wrote this little diary...
viewtopic.php?f=19&t=516
should help.....
Re: Silencer
Posted: Tue Mar 31, 2009 11:05 pm
by Camoradi
That's really useful, thanks. Gives me to confidence to start cutting away at the bodywork
Re: Silencer
Posted: Fri Apr 03, 2009 7:57 am
The reason for cutting right back to the chassis line is for max' airflow out of that area . You wont see underneath anyway from a standing position Kev'. You say the silencer is guarrenteed db's level ---- how is that possible without knowing the engine type and flywheel bhp
What quietens 150 bhp wont quieten 170 bhp . You could be losing bhp
It doesn't appear to be repackable
Hope it sorts the job long term
Re: Silencer
Posted: Fri Apr 03, 2009 9:20 am
by Camoradi
Hi Rob, I thought it might be better to cut the grp back to the chassis. More cutting for me tonight then
I told the suppliers of the silencer the engine and I overstated the bhp a little
when ordering. I've bought from them before and they're happy to noise test once it's fitted and at a later date if I get any problems. On a previous kit car I had they supplied a silencer for 96db and 3500 miles later it was still recording the same. Not sure exactly what they pack them with but it's some sort of honeycomb structure which doesn't break up. I'm pretty confident it will be OK. (famous last words)....
Thanks for your advice again, all much appreciated...
edited to add: Good luck with your new body work this weekend, assuming it arrives...
Re: Silencer
Posted: Fri Apr 03, 2009 9:39 am
Thanks Kev' . I've not actually heard yet that it will be here tomorrow but am assuming he'll phone me once it's collected from Duffee today . That will be a day of ' no work ' for Tim so I doubt he'll want it taking up space in his Sprinter van -- probably had to clear out all his work gear before collecting it
You never know , he may have ordered a complete light weight body for himself while Duffee was at it
Re: Silencer
Posted: Sat Apr 25, 2009 10:33 am
I was right
he has ordered a lightweight body for himself
to go with a new race chassis he will build specifically for the purpose
Don't know how long it will take , finances etc , but when it's built he will enter the WRDA series
If he does well the first season , it could ' just ' produce an order
I'm sure this is the right approach to sales even if it's not his number 1 priority
I would put money on him doing well straight out of the box
