It was good dry weather for the test day at Goodwood . Stuart came with me to help and get a spin around the circuit. Tony Jardine was there testing an A35 , possibly the one we saw at the Revival last year. Various Caterhams / one pretty quick , a single seater but not sure what it was plus a very nicely turned out MK1 Cortina going pretty quickly.
First time out I needed to go through the bedding in process for the DTC30's which meant being in everybody's way somewhat , braking along the straights at a fairly moderate speed x 8 then repeating 8 more much harder braking at around the 100mph mark. Takes a few laps because the brakes need cooling in between each application of the brakes. We kept tight to the inside of the circuit which was a bit tricky for cornering without braking . Then trickled our way back into the paddock not touching the brakes , apart from the handbrake , they were left to cool off for 30 minutes .
My assessment of them is that they are as good as the HAWK Black but easier not to lock up and nice to modulate and release .
Only problem I had was that with Stuart on board the front left tyre fouled the arch through corners , leaving melted rubber stuck around the inner arch
So looks like in my repairs to the hinge/flip reinforcing , I got it a little closer the before
That meant I had to run the rest of the day without Stuart on board
Quickest car there seemed to be the Caterham on 9 or 10 inch A048's but I didn't get to run with him except in my brake bedding session . He's in the SBD Speed series and noticed his name sown into his overalls as '' STARKEY '' , didn't catch his first name though. As usual he asked was my car a GINETTA
Didn't get my best time . Apparently I was clocked at 93.3 best . I found keeping hold of the car difficult so I may change to a larger steering wheel. At the end of 4 sessions I was absolutely knackered . I think being retired and not doing any heavy physical work has weakoned my arms/shoulders so really struggle with the 1.7 ratio now
So I need to get about 5 to 10 mm's more space under the left front arch somehow --- without misaligning the side pin attaching points ------------ that'll keep me busy before the 24th
It used 7 gallons which surprised me --- about 8.5 mpg
On the way back around the M25 , the inside rear trailer(4 wheeler)tyre burst so that was tricky to get off. Moved the front to the rear and trickled home at 50mph
