I used the following set up for my Fuel Injection system.
Run low pressure fuel line to engine bay using standard tank & low pressure fuel pump.
VW fuel injection pump & accumilator in engine bay.
This means a reserve of fuel is always available near the engine (cornering Ect) & the high pressure lines are limmited in distance. A small return to the fuel tank is required but again this is low pressure (the system may run without this, I put in in because I thought the lifter pump may increase the fuel pessure in the accumulator & injectors).
Any way seen 1 on ebay http://cgi.ebay.co.uk/FUEL-PUMP-ASSY-VW ... dZViewItem
If you go to German & Swedish you can get a Pump & Accumulator for approx £150 which I believe is good value.
May be of help to someone. Cheers
