Newer rear suspension?
se7ensport
Post by se7ensport »
just to add to the above: the concave rear arms and longer shocks would work really well if you planned on having a high ride height i.e. for rallying
drhunter
Post by drhunter »
Oop, I meant £120 ish
Springs were £101 in total from DemonTweeks and the compressors were £20 from my local motor-world!
alecmartin19
Post by alecmartin19 »
thats more like it! 220 was a little expensive!
Ady8077
Post by Ady8077 »
Hi again
Has nobody on the forum actually done the conversion?
I understand se7ensport's reservations, but it would be nice to hear a before and after opinion
Adrian
Cerberus
Re: Newer rear suspension?
Post by Cerberus »
Ady8077 wrote:Hi all
Can the newer bent rear lower arms be fitted to a car that had straight?
Thanks Adrian
Yes mine has had it done but not by me so i can't give you a before and after, Nathan did it(plasticfantastic) but last i heard he was upside down in OZ he might be back now give him a PM you never know.
:D
Anybody actually done it...
Hi Ady
Rob will be back off hols tonight, so he'll give you his two-pen-eth.
That's on two cars the green car he updated & his own red sprint car.
Andy Bailey too, but he's since sold his car.
Also got them on mine, but done something different.
I've modified the suspension pickup points & used the extra 2" to lower the car,
without compromising the spring/ride height/shock piston travel.
Ady8077
Post by Ady8077 »
Cheers guys
I'll await Rob's comments
Adrian
Ady8077
Post by Ady8077 »
Any Thoughts Rob?
Adrian
Ady8077 wrote:Any Thoughts Rob?
Adrian
For me there is no discussion . The first design was incorrect unless you required the car to emulate a ' giraff ' :shock: When JEREMY PHILLIPS designed the first Stylus , it didn't have the same spec' shocks/springs as P.Powells first sale car. Things were altered for manufacturing reasons , so then when people set their car to what looked like the correct ride height (visually looking at the RED demo car ----- J.P. spec ) it bottomed over rough roads and with passengers. I KNOW ---------- cos that's what happened to me --------- bent rockers , bent rear arms . A long story of constant developement improved the car massively through competition BUT Tim's new design rear arms were the answer , hence no new chassis went out without this change after that point. If you fit them , the result will transform the car on road and even more , on track. The only thing to be discussed really , is the spring rates/lengths. That will depend on the use to which the car will be put plus the individual and his weight.
Ady8077
Post by Ady8077 »
Hi Rob
Thanks for the reply, everyone said you were the best person to comment. I've never liked the way the car drove on poor roads, I'll await Tims recovery and order some new arms and his advice on spring rates etc
Anyone no the current price?
Adrian
Bikenuts
Post by Bikenuts »
So that just leaves a couple of questions; is it possible / worthwhile for those of us with early JP spec cars to fit the dropped style arms? What length shocks are fitted to the different variants i.e. J.P spec, P.P spec and Dropped (T.B spec sounds awful :shock: )
Antnicuk
Post by Antnicuk »
does anyone have any pictures of the 2 types of arm?
Ady8077 wrote:Hi Rob
Arms come complete with bushes fitted / powdercoated at £100 ish a pair from memory .
Adrian
Antnicuk wrote:does anyone have any pictures of the 2 types of arm?
There are plenty of pic's on here of the green one , I fitted with them plus previous ' bent ' straight arms. (on cars for sale topic)
Bikenuts wrote:So that just leaves a couple of questions; is it possible / worthwhile for those of us with early JP spec cars to fit the dropped style arms? What length shocks are fitted to the different variants i.e. J.P spec, P.P spec and Dropped (T.B spec sounds awful :shock: )
Tim designed the new arms to be retro fittable to all existing cars , even a Fury if the shock mount hole were moved a little :wink: I fitted 14 inch shocks with 9 inch springs to mine and the green car but with different spring rates . The shocks Tim fits / advises are 15inch with 10 or 11 inch springs . If you are skinny like me and don't carry passengers then 180 rears are fine. If you are 100 kgs ish , closer to 200 lbs. If cost is a concern/weight , then fit 1.9 inch x 15 inch shocks NOT 2.25 inch. Mark Berry , on this list owns the car I fitted new arms / shocks to(1.9 shocks x 9 inch springs) .
