Hi all
Has anyone managed to get rid of the flex in the doors
Mine shut ok if you push them in exactly the right spot, otherwise they catch on the striker
Adrian
Doors
- alecmartin19
door flex
How are your hinges attached to the inner door skin ?
steel plate
That's a bit heavy. More weight to make them sagg , it needs to be rigid but light . I didn't fit anything inbetween , simply used washers inside plus penny washers on the cockpit side then lifted the door behond normal shutting level before bolting extremely tightly. They then hung where I wanted them to and then I fitted the striker just slightly higher than appeared correct so the door would lift and be supported in the shut position. They are sagging a little now after a 1999 build but I'm too lazy to adjust them.
