With this in mind , I've come up with a design to acheive the same parameters but not needing the correct angled '' bent '' roundtube . They will be made in square box plus 3mm sheet and be fitted with the usual 28.5mm poly bushes.
Not being roundtube , they wont look so '' sexy '' if it's bling that motivates you but will acheive the same ends --- allow 15 inch shocks and 10 or 9 inch springs to be fitted , with that all important extra piston travel (5 inches)
Contact me '' PM '' if this is of interest then I'll make the jig up and get making
