Bottom Balljoint
CMA
Bottom Balljoint
Post by CMA »
Looking for the ball joints for the bottom of the front wishbones.
I thought they were transit but the taper is far too large. Transit ones are 16mm but the one I have on the car is about 13.3mm
So looking on here I found QR1774RHT but looking at the details here http://www.amazon.co.uk/Quinton-Hazell- ... B006ELSP6A the threads are different to what I have on mine. the shaft is M18x1.5 and the ball is M12x1.5 but that says its UNF so I guess that's not right either?
Any pointers or ideas?
Re: Bottom Balljoint
They are LDV van joints , steering from memory.
spegru
Post by spegru »
What was the conclusion on this in the end?
A part number would be perfect. :D
kevp
Post by kevp »
Try
http://www.clubstylus.be; Build ; Part Numbers.
:D
Shooter63
Post by Shooter63 »
Just ask for ldv van joints right hand, and check the joints in the box, they seem to have a habit of putting lh ones in Rh boxes, ask me how I know :evil:
norma
Post by norma »
I got fed up with the boots splitting & converted it to rose joints, was dead easy.
Shooter63
Post by Shooter63 »
norma wrote:I got fed up with the boots splitting & converted it to rose joints, was dead easy.
Can you expand on what parts you used and where you got them from, I like the sound of this.
hearbear
Post by hearbear »
Matt I'm sure will be along soon I'm sure he had a drawing for the pin to go in the stub instead of the ball joint and then convert to rod end.
Edit check this post out may have all you need
viewtopic.php?f=15&t=1369&hilit=Rod+end
norma
Post by norma »
Pictures speak a thousand words.....
https://drive.google.com/file/d/0B635OU ... sp=sharing
Hopefully the links work
where did you get the parts from?
norma
Post by norma »
are you running the MK2 escort uprights and the usual LDV bottom ball joints?
If so...could you kindly put the link to the exact parts that you used? I defiantly want to do the conversion before i set all my camber etc up as my boots have already been pinched and its not on the road yet!!
Thanks for your help!
norma
Post by norma »
Pete&Matt wrote:are you running the MK2 escort uprights and the usual LDV bottom ball joints?
Hi Matt - I bought them 5 years ago so don't have the info any longer. I think you can see what you need from my writing on the envelope in the picture?
Yes its escort struts.
Shouldn't take you too long to find the bits :-)
Did the spacers in the photos come from the same people?
How come you used 4?
My only other question for you is what did you do with the taper in the hub?
