Tim's Bias Bar
Tim's Bias Bar
Does anyone have any clue as to what thread Tim used on his own brake bias bar? Usual sizes are 3/8 or 7/16 UNF, of which it is neither!
Re: Tim's Bias Bar
Blimey , it's so long ago I fitted it , not sure but will try to find out after the weekend - busy with the Alfa at present.
Re: Tim's Bias Bar
I know mine is a 3/8unf, there were no nuts on it and I had to look for some to fit it.
Re: Tim's Bias Bar
Had a quick look at mine with torch then remembered not using nuts at all , I'd pushed a 15mm long piece of rubber fuel inj hose over the ' right side ' end . Marked it with white tippex so I can see if it moved a tad , just glancing down the footwell . Easy to adjust by turning the hose , counting turns looking at the tipex line
Hence - never did know what thread it was
Re: Tim's Bias Bar
it is 3/8 UNF. My supplier sent me 5/16 UNF nuts by mistake! Planks!
Would love to put a piece of hose etc over the end, but IVA wont allow it unfortunately!
Re: Tim's Bias Bar
Put the ''required'' nuts on for IVA then off once done and use my hose method
Re: Tim's Bias Bar
may well do. To be honest, I fiddled around with the bar when testing the brakes and found no difference in doing so! On a track it most likely shows I would expect
