body parts
Re: body parts
I'd already decided to black behind the lenses as they were before when the lights were in place. Since fitting the lenses though I've come to quite like them showing the body colour so I'm leaving it for now
Re: body parts
Looking good Rob you must be pleased, the paint job good.
Did you ever hear from Tim about light covers?
Re: body parts
Very pleased with the job Joe Middleton's done and he said he barely had to touch the arch extensions they were so smoothhearbear wrote:Looking good Rob you must be pleased, the paint job good.
RE- light covers , did you mean '' did I get any '' Yes and sold them apart from a set for myself. OR ------ did you mean have I heard whether the two left handed ones he put with the pack I bought , can be paired up If the latter --- no not heard a thing
I've glued the heat matting to the underside today and covered it with reflective ' bling ' Serves a real purpose with it being just 2mm's fibre glass but looks a touch flashy too
Can't wait to get in the damn car now --- the 27th of June's a looong way off
Re: body parts
Hi Rob
It was about the two left hand ones.
The 27th will come round quickly closely followed by the 28th when I'm of on holiday to drink some of the french wine and do nothing for 2 weeks.
Re: body parts
Painted underside plus heat mat
Re: body parts
Looking good
Be interesting to see how the heat pad works on the 27th
only 2 weeks now and that will go fast with silversone GP inbetween.
Glad to get TF back,no water leak so far and had all fans on in traffic on way back from northampton.
Re: body parts
Hopefully , that's the end of your head gasket woe's Looking forward to seeing Jenson at Silverstone
Although the Stylus is finished now , I seem to keep remembering things that ought to be looked at , so am still fettling If it was road registered I'd be out giving it a trial with the new set-up
Abingdon marshalling tomorrow on my usual spot ---- the last bend before the finish on the Abingdon course This corner sorts the men from the boys Flat in top if the nerves hold
Re: body parts
Grill mesh in now and carbon timing strut painted mat black as per MSA reg's
Re: body parts
looking great Rob - but I thought I remember somewhere that a fine mesh restricts air flow quite badly, I think you're supposed to go 1/2" or more....?
Re: body parts
Well it's 6mm square holes of 1mm diam' wire which is what I've always had without a problem . If you use 1/2 inch or more you totally defeat the object of a grill at all . Anything that can get through that will either block or bust your radiatornorma wrote:looking great Rob - but I thought I remember somewhere that a fine mesh restricts air flow quite badly, I think you're supposed to go 1/2" or more....?
I regularly took bees , flys , moths etc etc from the grill --- just imagine what a stone small enough to pass through 1/2 an inch wire would do to the rad' at 100 mph plus
You probably didn't notice the old grill because I painted it mat black
Re: body parts
Finally sorted the ' MSA Tow hook ' requirement Used Kevin's idea , using tow strapping but with the hook end velcro'd onto the underside of the front valance Having a grill made it awkward to velcro it on the inside of the grill valance ---- the scrutineers would probably moan about trying to reach it from behind in a hurry
Just have to hope the velcro holds it tight so's it doesn't drop off at speed and flail around whopping the radiator The male velcro is SIKAFLEXED onto the strapping then the female strip is SIKAFLEXED onto the fibre glass --- paint roughened up first The velcro area is about 25mm x 75mm --- we'll find out on Saturday
Re: body parts
Forecast is heavy showers
Re: body parts
No repeat incidents, please !!stylussprinter wrote:Forecast is heavy showers
How the Towbar Fit going ??
Re: body parts
MattD wrote:No repeat incidents, please !!stylussprinter wrote:Forecast is heavy showers
Taking the Cruiser in at 8-00am to get it fitted , electrics etc
Re: body parts
Tow bar fitted so all ready for Goodwood
